QualicoreHomes Posted May 13, 2022 Share Posted May 13, 2022 Hello, I'm hoping someone can help me with exporting Point Markers. I have a building that needs to get imported into a TopCon Total station. I put Point Markers at each building corner and at the center of the sonotube columns. Problem is, when exporting the file in a DXF format and imported into the total station the Point Markers become to separate lines and we lose the center point of the Point Marker. Is there something else that I should be using to get point references in the total station? Thanks for any help! Link to comment Share on other sites More sharing options...
Chopsaw Posted May 13, 2022 Share Posted May 13, 2022 Does the DXF carry the elevation data or are you better off with a CSV file with the locations and elevations ? Link to comment Share on other sites More sharing options...
QualicoreHomes Posted May 13, 2022 Author Share Posted May 13, 2022 The customer wants it in a DXF file. They are not using the elevations or heights and only use the total station for laying out exterior, party walls and deck columns. Are you saying a CSV file would export this better? Link to comment Share on other sites More sharing options...
Chopsaw Posted May 13, 2022 Share Posted May 13, 2022 Yes I believe so as I am not sure if chief exports the right information as DXF. I have another client that does the same sort of work and uses a CSV text file to load into the Total Station. I could send you a sample to test if you like. Or check the manual and see what the formatting should be for your model. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 13, 2022 Share Posted May 13, 2022 Here is one I am currently working on that happens to be metric but I can customize it to what you need. Site Plan Elevation Points.txt Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 13, 2022 Share Posted May 13, 2022 I developed a very simple to use, tried and true method for this a while back very specifically for use with Total Stations. The required 2D point data can literally be placed, compiled, and exported in about the same time it took me to type up this response. It just requires a small starter kit and some basic instructions. https://chieftalk.chiefarchitect.com/topic/25158-importing-points-into-a-ascii-format-for-total-station/?do=findComment&comment=202515 Link to comment Share on other sites More sharing options...
misterwiley Posted September 30, 2023 Share Posted September 30, 2023 On 5/13/2022 at 12:44 AM, Chopsaw said: Here is one I am currently working on that happens to be metric but I can customize it to what you need. Site Plan Elevation Points.txt 604 B · 94 downloads Hey @Chopsaw, I recently bought a total station and I would love to know how you are making this table for exporting. Link to comment Share on other sites More sharing options...
