AdeleMinton Posted May 11, 2022 Share Posted May 11, 2022 Hi there can anyone please advise how to cover end of the wall in camera view with drywall. I feel I've been though every setting I have. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 11, 2022 Share Posted May 11, 2022 I see you are not using the default wall colour. How did you change that ? Link to comment Share on other sites More sharing options...
AdeleMinton Posted May 11, 2022 Author Share Posted May 11, 2022 50 minutes ago, solver said: I notice there is no base on the wall. If you have a 0" thick layer as the exterior most layer in your wall definition, like maybe for paint, you will see this. You could do this. Thanks Eric, I'm not sure I follow.. Please see my wall set up Link to comment Share on other sites More sharing options...
AdeleMinton Posted May 11, 2022 Author Share Posted May 11, 2022 1 hour ago, Chopsaw said: I see you are not using the default wall colour. How did you change that ? in the default settings - Walls - interior walls - wall types - change colour. I actually duplicated the drywall in library, renamed to plasterboard as we refer to it and used a paint colour. for this to apply to each new plan you need to save an empty plan to your templates folder after changing your default settings.. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 11, 2022 Share Posted May 11, 2022 13 minutes ago, AdeleMinton said: in the default settings - Walls - interior walls - wall types - change colour. I actually duplicated the drywall in library, renamed to plasterboard as we refer to it and used a paint colour. Ok great you avoided the most common mistake of adding a thin extra layer to you wall definition that seems quite logical but does not work. I am also not sure what the issue might be but the plan file may show what the problem is. Link to comment Share on other sites More sharing options...
Solution glennw Posted May 11, 2022 Solution Share Posted May 11, 2022 You need to move your top Custom Plasterboard wall layer up to separate it from the main layer. 1 4 Link to comment Share on other sites More sharing options...
Chopsaw Posted May 11, 2022 Share Posted May 11, 2022 29 minutes ago, glennw said: You need to move your top Custom Plasterboard wall layer up to separate it from the main layer. That would do it. Good eye. Thanks Glenn. Link to comment Share on other sites More sharing options...
AdeleMinton Posted May 11, 2022 Author Share Posted May 11, 2022 3 hours ago, glennw said: You need to move your top Custom Plasterboard wall layer up to separate it from the main layer. Perfect thanks Glen, wow this has been annoying me for years lol Link to comment Share on other sites More sharing options...
buzzsaw204 Posted May 11, 2022 Share Posted May 11, 2022 8 hours ago, AdeleMinton said: Perfect thanks Glen, wow this has been annoying me for years lol Same here...i remembering asking on this couple years back. Link to comment Share on other sites More sharing options...
