armfx89 Posted May 4, 2022 Share Posted May 4, 2022 Hello I made a saltbox garage, with roof pitches 5/12 and 12/12. I need attic trusses but it seems attic trusses can't be automatically generated for this type of roof. Hence I tried to manually edit the webbing of the truss to create an attic space. However the custom webbing doesn't show in 3D Framing view but just the envelope. Saltbox Garage.plan Link to comment Share on other sites More sharing options...
GeneDavis Posted May 4, 2022 Share Posted May 4, 2022 Dif you build the attic room before generating trusses? Link to comment Share on other sites More sharing options...
Solution Chopsaw Posted May 4, 2022 Solution Share Posted May 4, 2022 1 hour ago, armfx89 said: Hence I tried to manually edit the webbing of the truss to create an attic space. However the custom webbing doesn't show in 3D Framing view but just the envelope. As Gene is suggesting it may well be possible to auto generate that condition but I have not tried. When manually editing trusses you can't use a "General Framing Member" as a structural component of the truss. You need to copy and modify an existing "Roof Truss Member" from the same truss envelope. General framing members can be used to trim with but will not show in your framing view even if the layer is turned on. 1 Link to comment Share on other sites More sharing options...
armfx89 Posted May 4, 2022 Author Share Posted May 4, 2022 57 minutes ago, GeneDavis said: Dif you build the attic room before generating trusses? Yes. Link to comment Share on other sites More sharing options...
armfx89 Posted May 4, 2022 Author Share Posted May 4, 2022 38 minutes ago, Chopsaw said: As Gene is suggesting it may well be possible to auto generate that condition but I have not tried. When manually editing trusses you can't use a "General Framing Member" as a structural component of the truss. You need to copy and modify an existing "Roof Truss Member" from the same truss envelope. General framing members can be used to trim with but will not show in your framing view even if the layer is turned on. Thanks, i'll try that Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 4, 2022 Share Posted May 4, 2022 2 hours ago, armfx89 said: I made a saltbox garage, with roof pitches 5/12 and 12/12. I need attic trusses but it seems attic trusses can't be automatically generated for this type of roof. You should be able to get attic trusses if you place the required interior walls and set the ceiling height appropriately. Link to comment Share on other sites More sharing options...
seanmcl Posted August 24, 2022 Share Posted August 24, 2022 @armfx89Did you ever find a solution to this. It is EXACTLY what I need to do! Link to comment Share on other sites More sharing options...
Chopsaw Posted August 25, 2022 Share Posted August 25, 2022 9 hours ago, seanmcl said: Did you ever find a solution to this. It is EXACTLY what I need to do! Only the original poster can mark an answer as the "Solution" so if you can't make Michaels solution work give mine a try. Link to comment Share on other sites More sharing options...
