How to remove tray ceiling?
GeneDavis
Go to solution Solved by Kbird1,
Zipped X13 file attached.  In the walkout basement, I did a tray drop in the game room, and something happened in the adjacent hall, causing it to have a full drop.  How do I restore the hall to a no-tray situation.
Screencap with both rooms highlighted is attached.  I cannot seem to find a check box to uncheck, and I cannot recall doing anything to upset that hall room structure's ceiling.
Wilmington modern.zip
  • Solution
haven't looked at plan but "auto trey ceilings" do not like invisible walls/Room Dividers, which it appears you have between the two areas.
In that case I use a P.Solid with a Hole for the Tray instead, with the Room's Ceiling set to the Higher height.
Tray Ceilings the Old way  PDF : Ceiling_Creating-a-trey-or-coffered-ceiling-using-polyline-solids.pdf
