javachip24k Posted January 12, 2015 Share Posted January 12, 2015 Am'I doing something wrong or this is some CA glitch in the program. First, when closing under the stairs the wall base molding is not continued as it would with crown when using soffit where crown will recognize soffit being part of the wall and wrap around it. Second using the Newel out of the box, why stair tread cuts through the post? Third why there is missing spindles at the wall and at the newel post... creating none code compliant spindle spacing? Is this something CA messed up (@ this price should this be an issue)? I'm doing something wrong? Or this have to be done manually? Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted January 12, 2015 Share Posted January 12, 2015 I am no stair expert but the base molding has to be done manually unless you put a wall under the stair. try adjusting baluster spacing. Many requests have been made for work on the stairs and have been ignored. I understand they did not do anything for the new release either. Very Disappointing. ;o( Link to comment Share on other sites More sharing options...
Kbird1 Posted January 12, 2015 Share Posted January 12, 2015 did you try making the wall under the stair flush with the main wall instead of inset ? if a soffit ? I think Dennis is right...do manually The tread issue is probably a combination of the newel size and the tread overhang not being quite correct ie larger newel or less overhang should fix the glitch. M. Link to comment Share on other sites More sharing options...
chief58 Posted January 12, 2015 Share Posted January 12, 2015 was your wall under the stairs done in the dbx box that you have open underneath unchecked if that is the case I would draw a wall and put it about 1" inside of the stairs and it should show then Link to comment Share on other sites More sharing options...
javachip24k Posted January 12, 2015 Author Share Posted January 12, 2015 Thanks guys for the reply. Is what I been doing using the wall there to make it work or using a line and converting to 3d molding, but we shouldn't have to do that. Also if you have crown molding in the room and you create a stairway, the crown should break at stairway points instead of keep going another pain in the A$$ and a wasted time to get rid of it. As spindles go, I think you only have the option to adjust spacing on the landing rails only, on the stairs you don't get that option in dbx. Also when railing is done on the stairway along the wall,would be a good idea to add wall returns being this the code and it would look much better in the 3d view. Hopefully they get this right i the new version. Link to comment Share on other sites More sharing options...
