Designers_Edge Posted April 12, 2022 Share Posted April 12, 2022 I have clients that want 3D images of a view of their backyard through their dining room and living room windows. They are removing a 2 story sun room. I have searched Chief as I remember an article about customizing and creating backdrops. What I would like to know and can’t find is the size these images should be importing them as backdrops. I have tried before and some of my attempts have been very distorted -i.e. the trees and shrubs are giant size and you just see a huge trunk out the window instead of a wooded backyard. I need the backdrop to provide a realistic view. Thank you for any advice with this. Link to comment Share on other sites More sharing options...
HumbleChief Posted April 12, 2022 Share Posted April 12, 2022 I've used a poly line solid with the desired picture placed outside the windows. Worked OK and can be customized much more than a 'backdrop'. 1 Link to comment Share on other sites More sharing options...
MarkMc Posted April 12, 2022 Share Posted April 12, 2022 I use Build, Image, Billboard. Always take several shots, turn off backdrop in camera, reduce sun and back drop intensity. Adjust size and height. I like that it can be set to always face camera though sometimes not ideal. Also that it lets light in but doesn't change the color of the light in PBR. Works easiest if the billboard does not have to be really far from window in many cases. I've also used the in interior doorways if there was a nicely detailed room that I did not need to draw but want to show. Just grabbed something for this one quickly. Somewhere I have others from a few years back. 1 1 Link to comment Share on other sites More sharing options...
HumbleChief Posted April 12, 2022 Share Posted April 12, 2022 7 minutes ago, MarkMc said: I use Build, Image, Billboard. Always take several shots, turn off backdrop in camera, reduce sun and back drop intensity. Adjust size and height. Never knew there was a 'Billboard' in Chief. Thanks Mark 1 Link to comment Share on other sites More sharing options...
Designers_Edge Posted April 12, 2022 Author Share Posted April 12, 2022 Mark, Where are you getting your image from?? I read about this feature, but it did not mention importing an image taken with a camera or my iPhone. Is that what you are doing. Link to comment Share on other sites More sharing options...
Designers_Edge Posted April 12, 2022 Author Share Posted April 12, 2022 Larry, I like the idea of trying a polyline solid. Link to comment Share on other sites More sharing options...
MarkMc Posted April 12, 2022 Share Posted April 12, 2022 14 minutes ago, Designers_Edge said: Where are you getting your image from?? Place image in folder XYZ:\...\Chief Architect Premier X13 Data\Images. Place billboard, navigate to image. There is also an option to create a new image though that doesn't seem to work to paint the billboard and not an option to select that I see? 1 Link to comment Share on other sites More sharing options...
Designers_Edge Posted April 12, 2022 Author Share Posted April 12, 2022 Thank you so much for all of these tips! So appreciated Link to comment Share on other sites More sharing options...
