Active Layer Display Not Working
Adam_Gibson
Only on one machine, when I select an object (wall, dimension, etc.), nothing gets selected on the active layer display options panel. I assume it's a preference somewhere, although I don't know why anyone would not want it. Anyway, I can't find a way to turn it on. Any ideas?
4 minutes ago, Adam_Gibson said:
OMG, you're so right! Jeez and thank you!
You are quite welcome Adam...    That last person I helped did not even know that was a setting let alone where to find it. :(
No not quite like you.  Pretty sure most people pass right on by that one because of the way it is set up.  If the setting was reversed and labeled as "Show Selected Layers" then it would make a lot more sense to most people.
  • 3 months later...
  • 4 months later...
  • 1 month later...
