Toolbars missing in x13
DianeP
Go to solution Solved by Chief_QA,
  • Solution
If you just want your X12 toolbars in X13 you can reset the migration and then when prompted migrate your toolbars over.  To reset the migration just go to Edit>Preferences and go to the Reset Options panel, on this panel there will be a button Reset Migration.  Click it, restart Chief and it will prompt you for the migration, select only the toolbars and that should get you your X12 toolbars into X13.
Ed, Thanks so much.  Will the rest of the migration stay the same (libraries, layout template default, etc)?
