mtldesigns Posted February 12, 2022 Share Posted February 12, 2022 Needing to do some custom muntin's, and found the how to, but not finding the "Load Muntins" button.. any ideas on where this is hidden? 1 Link to comment Share on other sites More sharing options...
mtldesigns Posted February 12, 2022 Author Share Posted February 12, 2022 Never mind, I found it as soon as I hit send.. Link to comment Share on other sites More sharing options...
Dermot Posted February 12, 2022 Share Posted February 12, 2022 For those that run into this problem in the future, here is the tech article that explains how to create custom muntins: https://www.chiefarchitect.com/support/article/KB-00930/creating-custom-muntins.html Normally, the Load Muntins button will appear when you select the window or door in an elevation view when the program finds a suitable cad block to load. The program can sometimes be a bit finicky about what it considers a suitable cad block though. For example, the cad block has to cover a certain percentage of the window glass to be considered suitable so you can't just draw a single line, block it, and make custom muntins out of it. Link to comment Share on other sites More sharing options...
Solution mtldesigns Posted February 12, 2022 Author Solution Share Posted February 12, 2022 On 2/12/2022 at 2:36 AM, Dermot said: suitable cad block though Expand a cad block is the key. I had drawn the new muntin's.. but forgot to covert to a cad block. Once I did, the icon popped up. Link to comment Share on other sites More sharing options...
cjanderson66 Posted September 5, 2023 Share Posted September 5, 2023 On 2/12/2022 at 2:36 AM, Dermot said: For those that run into this problem in the future, here is the tech article that explains how to create custom muntins: https://www.chiefarchitect.com/support/article/KB-00930/creating-custom-muntins.html Normally, the Load Muntins button will appear when you select the window or door in an elevation view when the program finds a suitable cad block to load. The program can sometimes be a bit finicky about what it considers a suitable cad block though. For example, the cad block has to cover a certain percentage of the window glass to be considered suitable so you can't just draw a single line, block it, and make custom muntins out of it. Expand On 2/12/2022 at 1:24 AM, mtldesigns said: Needing to do some custom muntin's, and found the how to, but not finding the "Load Muntins" button.. any ideas on where this is hidden? Expand I know that there are over 1300 toolbar buttons but can someone tell me where I can find the Load Muntin toolbar button. I have done a search and it does not show up at all and I cannot seem to find it anywhere. Where did you find it Michael? Dermot, I saw this being done on one of the Love shack drawings but did not see the Load Muntins button and it is not showing up when I pick my window... Link to comment Share on other sites More sharing options...
tundra_dweller Posted September 5, 2023 Share Posted September 5, 2023 On 2/12/2022 at 2:36 AM, Dermot said: Normally, the Load Muntins button will appear when you select the window or door in an elevation view when the program finds a suitable cad block to load. The program can sometimes be a bit finicky about what it considers a suitable cad block though. For example, the cad block has to cover a certain percentage of the window glass to be considered suitable so you can't just draw a single line, block it, and make custom muntins out of it. Expand @cjanderson66 Link to comment Share on other sites More sharing options...
