GeneDavis Posted January 22, 2022 Share Posted January 22, 2022 I build the frameless cabinets in Chief X13 as "framed," separation default set to 3/4", full overlay amount set to 11/16". Double-door cabs show doors tight. Do I have to fake this with a vertical split to get the 1/8" margin between doors? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 22, 2022 Share Posted January 22, 2022 Why are you building them as "framed"? 1 Link to comment Share on other sites More sharing options...
MarkMc Posted January 22, 2022 Share Posted January 22, 2022 2 hours ago, GeneDavis said: Do I have to fake this with a vertical split to get the 1/8" margin between doors? Yes if you need the look OR if actual size of doors matters. Note that even with 1/16" reveal as the default you Chief makes the gap on a double door 1/32", which would bind IRL. 42 minutes ago, Joe_Carrick said: Why are you building them as "framed"? It works better and has more control. I was making frameless cabinets from framed with 3/4" separation before Chief added frameless. I tried it, and check every new release, but have never found a reason to use the frameless option. I just don't get it. Now if it would allow for a true 5/8" side then maybe. reveals.plan Link to comment Share on other sites More sharing options...
