DIYJon Posted January 6, 2022 Share Posted January 6, 2022 I've spent the past hour trying to figure this out. When I draw a line, it snaps to the 1" increment. I'm trying to create a custom u-channel profile for a molding and the channel is small, but I'm unable to actually draw a line the right length. Holding CMD gives me 100% control and 0% snapping. I just need to be able to reduce the snap resolution to 1/32 or 1/16". Am I expecting something that CA can't do? Link to comment Share on other sites More sharing options...
Chopsaw Posted January 6, 2022 Share Posted January 6, 2022 You can override the snap grid or set it to whatever you need in General plan defaults. But if that is too much of a bother you can open up the DBX and set the length manually. 1 Link to comment Share on other sites More sharing options...
robdyck Posted January 6, 2022 Share Posted January 6, 2022 When the 1" snap grid is on, drawing a line will (obviously) snap to the grid and segments will want to be in 1" increments. To draw a shorter segment, start to draw the line, then press tab. You can then enter the desired length. Another simple way to draw a small u-channel is to draw a 1x1 polyline, then resize by using the temp dimensions, transform / replicate, or adjusting by snapping to line segment center points. Link to comment Share on other sites More sharing options...
Chopsaw Posted January 6, 2022 Share Posted January 6, 2022 55 minutes ago, robdyck said: When the 1" snap grid is on, drawing a line will (obviously) snap to the grid and segments will want to be in 1" increments. To draw a shorter segment, start to draw the line, then press tab. You can then enter the desired length. I was actually going to suggest that Rob but it does not work. You would think it should but. Link to comment Share on other sites More sharing options...
robdyck Posted January 6, 2022 Share Posted January 6, 2022 1 hour ago, Chopsaw said: I was actually going to suggest that Rob but it does not work. You would think it should but. Sorry, what doesn't work? Using Tab? Link to comment Share on other sites More sharing options...
Chopsaw Posted January 6, 2022 Share Posted January 6, 2022 1 minute ago, robdyck said: Sorry, what doesn't work? Using Tab? Drawing a cad line shorter than 1" with 1" snap grid turned on. At least it would not work for me. Link to comment Share on other sites More sharing options...
Dermot Posted January 6, 2022 Share Posted January 6, 2022 Hitting tab and specifying a length less than 1" works for me. Turning off the grid snaps also works. So does specifying a smaller snap grid size. So does using the Input Line tool. And so does specifying the actual start point, end point, or line length in the specification dialog. Should be able to use whatever method you like the best. Link to comment Share on other sites More sharing options...
robdyck Posted January 6, 2022 Share Posted January 6, 2022 @Chopsaw It only works using tab and you need to be zoomed in to pretty tight to the grid, about 24" seems to do the trick. edit... turning off grid snaps makes no difference to this function, at least not in my chair. 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted January 6, 2022 Share Posted January 6, 2022 2 minutes ago, Dermot said: Should be able to use whatever method you like the best. I agree. 3 minutes ago, Dermot said: Hitting tab and specifying a length less than 1" works for me. Unfortunately this and many other items that I have run into in the past do not work at my normal comfortable working zoom levels. Perhaps this should have some sort of adjustable Preference setting ? 5 minutes ago, robdyck said: @Chopsaw It only works using tab and you need to be zoomed in to pretty tight to the grid, about 24" seems to do the trick. Thanks Rob. If you did not clarify that I would have just walked away and had to use a less effective tool. Link to comment Share on other sites More sharing options...
