HectorHBO Posted December 15, 2021 Share Posted December 15, 2021 I'm having issues with x13. Every time I'm busy designing the functions option stops operating, I can't select or draw anything. Then I have to restart the program and this exercise happens every 5 to 10min Link to comment Share on other sites More sharing options...
Chopsaw Posted December 15, 2021 Share Posted December 15, 2021 Could you expand on that a little more ? By "functions" do you mean that you are unable to select any tools from the toolbar ? Do you get any sort of error message ? Link to comment Share on other sites More sharing options...
HectorHBO Posted December 15, 2021 Author Share Posted December 15, 2021 I can select all the tools except but I can't draw a wall or any of the commands I've selected. Than I have to restart. Link to comment Share on other sites More sharing options...
Chopsaw Posted December 15, 2021 Share Posted December 15, 2021 Not sure I have ever heard of a situation like that before so not quite sure what to suggest other than possibly a system reboot. Possibly someone else may have a suggestion. Unless it is something simple like the batteries running low in your mouse. Otherwise please give tech support a call in the morning. Link to comment Share on other sites More sharing options...
HectorHBO Posted December 15, 2021 Author Share Posted December 15, 2021 Don't you think it can be a setting, because I'm trying to find the same problem on youtube but nothing? But thanks for your help Link to comment Share on other sites More sharing options...
Chopsaw Posted December 15, 2021 Share Posted December 15, 2021 It may be this so tech support might be happy to hear from you to get your details. Link to comment Share on other sites More sharing options...
Doug_N Posted December 15, 2021 Share Posted December 15, 2021 I have experienced this same phenomenon several times. All of a sudden I can't click on anything. The cursor focus function stops working for a bit. Usually this comes back if I refresh the page or go to a different window and come back to CA again. This does not happen with other windows programs, so my assumption is that CA is processing something and that uses so many resources that it can't process the click buffer. This does not seem to affect the keyboard buffer for windows though because I can alt-tab to a different program. I have not had to shut down CA and restart it though. Link to comment Share on other sites More sharing options...
HumbleChief Posted December 15, 2021 Share Posted December 15, 2021 Curious, are any of you using DropBox? I had crazy delays when using Chief, as that's what I use all day, and THINK I tracked it down to DB taking forever to synch download or whatever it does. I deleted DB, reinstalled it and back to OK again. Not sure if OneDrive or other cloud services might cause similar delays? Link to comment Share on other sites More sharing options...
Doug_N Posted December 15, 2021 Share Posted December 15, 2021 No, not me. Link to comment Share on other sites More sharing options...
