J_Mack Posted December 1, 2021 Share Posted December 1, 2021 I often use soffits in showers and polyline solids for shower curbs, benches, etc. To my knowledge you can only apply custom backsplashes to walls, so it's not an easy task to apply to a soffit or polyline solid. My work-around is to apply a custom backsplash to an adjacent wall and move it in front of the soffit, curb, or bench in plan view. Is there an easier way to do this? Thanks! Link to comment Share on other sites More sharing options...
glennw Posted December 1, 2021 Share Posted December 1, 2021 I don't fully understand. Why do you need to apply a splashback? Why not just apply a material to the soffit or solid. If you want the material to run in different directions, explode the object into faces, create a new material that runs in the other direction and apply it to the exploded face. 1 Link to comment Share on other sites More sharing options...
rgardner Posted December 1, 2021 Share Posted December 1, 2021 2 minutes ago, glennw said: explode the object into faces, create a new material that runs in the other direction and apply it to the exploded face. I am assuming you want different materials on different faces as well. IF that is the case what Glenn is saying here makes the solid a separate surface on each plane. Top, bottom, left, right, front, back, etc... Link to comment Share on other sites More sharing options...
Joe_Carrick Posted December 1, 2021 Share Posted December 1, 2021 Also, you can use a "Wall Material Region" in lieu of a "Custom Backsplash". But as Glenn said, using a Solid "Exploded" allows different materials to be applied to each face. Link to comment Share on other sites More sharing options...
Pickle_Board Posted September 8, 2022 Share Posted September 8, 2022 I started reading this thread because I'm having a similar issue, but the suggest "exploded" feature won't help me. The reason I need to apply a backsplash and not apply the material directly is to run different tiles, for instance right now I am trying to do 3 tiles high of subway and then a thin stripe of black tile. On the side walls I have no issues making backsplash, but on the back wall I need a 1/2 wall that creates a ledge and then the tile continues up. If I use a 1/2 wall I can't apply backsplash to the wall behind it. So then I tried using a poly line solid to build the 1/2 wall which allows me to tile the top 1/2 but I still can't add the tile properly to the solid. Any thoughts on solutions for this? Using Chief Architect Interiors X14 Thanks so much to anyone taking the time to read/respond! Julie Link to comment Share on other sites More sharing options...
rgardner Posted September 8, 2022 Share Posted September 8, 2022 36 minutes ago, Pickle_Board said: I started reading this thread because I'm having a similar issue, but the suggest "exploded" feature won't help me. The reason I need to apply a backsplash and not apply the material directly is to run different tiles, for instance right now I am trying to do 3 tiles high of subway and then a thin stripe of black tile. On the side walls I have no issues making backsplash, but on the back wall I need a 1/2 wall that creates a ledge and then the tile continues up. If I use a 1/2 wall I can't apply backsplash to the wall behind it. So then I tried using a poly line solid to build the 1/2 wall which allows me to tile the top 1/2 but I still can't add the tile properly to the solid. Any thoughts on solutions for this? Using Chief Architect Interiors X14 Thanks so much to anyone taking the time to read/respond! Julie This is totally doable but very separate in nature. Better to post this as a separate post. There is many ways to accomplish it and one would be a custom material instead of individual backsplashes. In this way you can set it so all grout lines line up in the X,Y axxis. Post it up and you will have lots of support. Link to comment Share on other sites More sharing options...
Pickle_Board Posted September 8, 2022 Share Posted September 8, 2022 @rgardnerthanks! I totally get what you mean with a custom material, makes sense. Link to comment Share on other sites More sharing options...
