DesiSusan Posted November 30, 2021 Share Posted November 30, 2021 Home Designer Pro 2021 fully updated. When I send an elevation view to a layout, I cannot resize nor select and move the entire elevation. Ultimately I am trying to combine 2 elevation views and some text from one of them into 1 presentation. Is there a better way, than going to a layout. BackElevation.layout MBath1.plan BackElevation.pdf Link to comment Share on other sites More sharing options...
joey_martin Posted November 30, 2021 Share Posted November 30, 2021 Link to comment Share on other sites More sharing options...
DesiSusan Posted November 30, 2021 Author Share Posted November 30, 2021 I don't think I have that in my PRO version. This is what happens when I try to resize. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 30, 2021 Share Posted November 30, 2021 Have you tried "rescale" the Layout Box? Link to comment Share on other sites More sharing options...
joey_martin Posted November 30, 2021 Share Posted November 30, 2021 Hold SHIFT when selecting the layout box and the corner nodes should disappear leaving one single node at the top of the layout box that can be used to change the size/scale of whats in the box. 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 30, 2021 Share Posted November 30, 2021 17 minutes ago, joey_martin said: Hold SHIFT when selecting the layout box and the corner nodes should disappear leaving one single node at the top of the layout box that can be used to change the size/scale of whats in the box. AFAIK that only changes the size of the Layout Box, not the size of what's inside it. Re-scale actually does both. Link to comment Share on other sites More sharing options...
DesiSusan Posted November 30, 2021 Author Share Posted November 30, 2021 JoeCarrick - How do you do the rescale? JoeyMartin - that helps a bit. The picture gets fuzzy tho Link to comment Share on other sites More sharing options...
SHCanada2 Posted November 30, 2021 Share Posted November 30, 2021 as joe says rescale. do this by right clicking on the layout box, click "rescale layout view" from the shortcut menu. The picture becomes unfuzzy when you print some camera views cannot be rescaled with the menu. hold down the X key and click and drag a corner to make the window larger Link to comment Share on other sites More sharing options...
Solution Joe_Carrick Posted November 30, 2021 Solution Share Posted November 30, 2021 6 minutes ago, DesiSusan said: JoeCarrick - How do you do the rescale? Select the Layout Box Click on the "ReScale" icon on the Edit Toolbar. It looks like a short ruler. Set the desired Scale You probably want both Layout Boxes to be the same scale. 1 Link to comment Share on other sites More sharing options...
DesiSusan Posted November 30, 2021 Author Share Posted November 30, 2021 So I got the views to the right size by sending them to layout by themselves, and then using JOECARRICKS rescale. Now can I send the text boxes to the layout on their own? My version of rescale is a bit different (under transform/replicate dialog box. My short ruler is just for dimensions. Link to comment Share on other sites More sharing options...
