How to effectively reuse text with different annotation sets?
PMMully
In doing some construction detail work, I have come across the need to reuse text between detail diagrams that are using different annotation sets for scaling on the layouts. For example, I might have a block that says:
4" 3000 PSI fiber mesh reinforced concrete with
continuous pour perimeter
In one diagram, it may be needed in 1/2", in another 1". This is an occasional use case that is driven by reusing typical detail to create job specific detail.  I am checking to see if there is a slick way to do this that "auto-adjusts" to the annotation set in play? So far I have been going in manually and changing it. I had considered putting multiple entries of this in the library but I only want one copy of the text to keep maintenance down.
4 hours ago, rlackore said:
You could use Text (not Rich Text) and use Text Specification>Text Style>Source of Text Style>Use Layer for Text Style. Then you can control the text size using the Annotation Set and associated Layer Set.
You can also set this up with "Saved Plan Views".  The key is to "Use Layer for Text Style".
