arched wall opening
ChiefuserMathews
Attached is a AutoCAD file for reference. I am trying to create an arched opening as shown in the elevation in CA. I tried to use door way and add double arch, but the height locks at 144". Is it possible to create a solid in elevations and subtract? Tried to create polyline solid, but I dont know how I can subtract that from the wall. Could someone help me to achieve this?
Projection Screen CA.dwg
Only a doorway or Pass-thru Window could work.  You can't subtract a solid from a wall.  Also I don't understand what you mean by the height locks at 144".
Post the Plan so we can help.  You can also post a PDF of the arch to show what you are trying to get - dwg's are not that useful.
More like this?
1612281806_ScreenShot2021-11-28at9_59_58am.thumb.jpg.d5579e4cda48b161c74714acaea102cc.jpg
Or....there is a way of creating a custom shaped wall opening (not a door).
Have a look in the help file for Edit Wall Cutout Polyline.
You can attach a custom shaped Wall Cutout Polyline to a symbol (by using Inserts Into Wall) and then hide the symbol so that it is not visible.
Here is a very quick freehand hole in wall attached to an espresso machine.
1076346212_ScreenShot2021-11-28at10_37_28am.thumb.jpg.ee8705682f3937235fd48f7879e08973.jpg
  • Upvote 2
    30681
    iutentic99
    iutentic99
