Custom Countertops - Can't Hide Fillet Cross points?
aslan-Ryan
My first guess is that you are using point to point dimensions? that would do it. Else sometimes if a manual or end to end dimension is in place and an object it replaced those will show up. I simply never use P to P dimensions unless I have no choice.
Yes they look like Pt to Pt Dimension Markers to me too...this will happen IF they don't snap to a Dimension-able Point/Surface,
in which Case the Pt to Pt Dimension will place it's own 4" Radius (default) Marker , you can open these and make them smaller
like 1/4" or 1/2" R and they are almost un-noticeable .....could change the Default Marker Radius too I guess for future placements.
