Doug_N Posted November 5, 2021 Share Posted November 5, 2021 I know that the wall can be fixed by manually dragging the top of the basement wall up, but is there some automatic way to prevent this? Below Grade Entrance.zip Link to comment Share on other sites More sharing options...
Chopsaw Posted November 5, 2021 Share Posted November 5, 2021 Could you do without a defined room for your two sided railing ? That seems to help quite a bit but still some misalignment on the front and back walls for some reason. Link to comment Share on other sites More sharing options...
Doug_N Posted November 5, 2021 Author Share Posted November 5, 2021 Worth a try. I will see how that goes. Link to comment Share on other sites More sharing options...
Doug_N Posted November 5, 2021 Author Share Posted November 5, 2021 That solves one problem but then the stairs don't show in the first floor plan. The reason for making the railing wall defining is so that the room can be open to below. Link to comment Share on other sites More sharing options...
MPDesign Posted November 5, 2021 Share Posted November 5, 2021 After spending an hour fussing! I discovered that the wall type makes a difference in this situation. If you change it to a standard block wall type and add the (energy wall) on the inside separately, mark it no room def. Link to comment Share on other sites More sharing options...
Doug_N Posted November 5, 2021 Author Share Posted November 5, 2021 Michael, Thank you for your post. You were on the right track. The actual answer came from Vincent BennettTechnical Support AnalystChief Architect I put in a trouble ticket because I thought this was a bug of some sort. Vincent pointed out that the interior framing should have been moved to the main layer. That solved the problem. Thanks Vincent for pointing out the problem with the wall assembly definition. Link to comment Share on other sites More sharing options...
