HumbleChief Posted October 23, 2021 Share Posted October 23, 2021 Seems like they need to be spec'd every time with a saved wall type. True? Link to comment Share on other sites More sharing options...
Chopsaw Posted October 23, 2021 Share Posted October 23, 2021 Yes I believe you are correct Larry. If you have some set up you would like to keep and reuse, save them in the library. Then make a custom tool bar if you find you use them a lot. 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted October 23, 2021 Share Posted October 23, 2021 24 minutes ago, Chopsaw said: Yes I believe you are correct Larry. If you have some set up you would like to keep and reuse, save them in the library. Then make a custom tool bar if you find you use them a lot. CS is right , they save to the Library without issues , Chief's Straight Glass Pony Wall is exactly that. If you save/draw ( you can then delete again) them back into your Template Plan, they should also be available on the WallTypes Dropdown for every job. M. Link to comment Share on other sites More sharing options...
