Sump Pump Pit
javachip24k
  • 3 weeks later...
Sketchup has tendency to do that to get a better rendering quality. You can get a third party poly cruncher programs which will reduce the file size. I could have kept smooth sides making like a plain cylinder, but I guess I like to play a little so I made it look like a real sump pit and if need it it will look real.
​If that a concern, just make a cylinder using solids and cut a hole in it to make a pit.
  • 1 year later...
Use a circle tool, draw a circle 10 1/16" radius where you want the pump. use convert polyLine tool and convert that circle to a <Hole in the floor platform> and drop your sump-pump into the hole. Adjust the hole up or down and use center tool to to center it over the hole so it looks like the picture.
