Extend Stair Rails at Wall ( Top &/or Bottom )
Joe_Carrick
Thanks Scott.
Now the only thing that needs to be fixed is the fact that the railing at the bottom should extend at the slope a full tread depth before becoming horizontal.  Check the referenced link to see what I mean.  This is a standard code requirement.  Only if the extension is greater than a full tread should the extension become horizontal at that distance.
3 hours ago, scottharris said:
Be sure to click on the ‘top rail’ in the dialog panel.  Then you should be able to check the ‘extend’ option.
Ok nice..... perhaps a Note could be added to the DBX Panel to make that more obvious?.
thanks,
