Subfloor OSB showing up in stairwell windows
mtldesigns
Looks like a possible glitch but it appears from the picture to be the subfloor at the height of the open below room.  You could delete the subflooring from the floor definition of the open below room. But I would probably try rebuilding the main floor system and if that doesn’t work saving and restarting your computer before I did that.
8 hours ago, Chopsaw said:
I meant the window not you
I know..  :-)
No one even noticed the pretty 2019 Silverado in the driveway.. smh..
I'm going to get the floor plan schematic out today..  then if I still can't get it to delete by testing some thing out, will post.
