mtldesigns Posted September 25, 2021 Share Posted September 25, 2021 Never saw this before, any ideas? I have a three story house, two sets of staircases. On each level I have subfloor OSB showing up in the window. These windows are all the same (copied).. the doubles are mulled. Link to comment Share on other sites More sharing options...
Chopsaw Posted September 25, 2021 Share Posted September 25, 2021 Maybe try CTRL + X and CTRL + ALT + V and see if a quick trip to the hospital helps. Link to comment Share on other sites More sharing options...
mtldesigns Posted September 25, 2021 Author Share Posted September 25, 2021 What.... ? I did the Control X and Control/Alt/V.. now I got the osb on both sets. NOT going to any hospital if I can help it.. Link to comment Share on other sites More sharing options...
Chopsaw Posted September 25, 2021 Share Posted September 25, 2021 Oops.... Maybe CTRL + Z then... What did you do differently with the good ones originally ? Link to comment Share on other sites More sharing options...
Chopsaw Posted September 25, 2021 Share Posted September 25, 2021 You may need to fiddle with the open below room def a bit. Take a look in vector view to see if there are any other clues. Or you can always post the plan. Link to comment Share on other sites More sharing options...
rgardner Posted September 25, 2021 Share Posted September 25, 2021 Looks like a possible glitch but it appears from the picture to be the subfloor at the height of the open below room. You could delete the subflooring from the floor definition of the open below room. But I would probably try rebuilding the main floor system and if that doesn’t work saving and restarting your computer before I did that. Link to comment Share on other sites More sharing options...
Chopsaw Posted September 25, 2021 Share Posted September 25, 2021 3 hours ago, mtldesigns said: NOT going to any hospital if I can help it.. I meant the window not you. Sometimes just putting something into memory or even the library seems to have a healing effect. Link to comment Share on other sites More sharing options...
mtldesigns Posted September 25, 2021 Author Share Posted September 25, 2021 8 hours ago, Chopsaw said: I meant the window not you I know.. :-) No one even noticed the pretty 2019 Silverado in the driveway.. smh.. I'm going to get the floor plan schematic out today.. then if I still can't get it to delete by testing some thing out, will post. Link to comment Share on other sites More sharing options...
