AimeeTotalHome Posted September 15, 2021 Share Posted September 15, 2021 I am selecting the Library Browser button in the TOOL BAR as well as the VIEW drop down menu, neither will bring up the catalogs. Was there an update that we need to get to access them again? Chief Premier X12 Link to comment Share on other sites More sharing options...
Solution rgardner Posted September 15, 2021 Solution Share Posted September 15, 2021 They are probably stuck on your other screen. Try preferences>reset options>reset side windows 3 Link to comment Share on other sites More sharing options...
AimeeTotalHome Posted September 15, 2021 Author Share Posted September 15, 2021 THANK YOU THAT WORKED! Link to comment Share on other sites More sharing options...
rgardner Posted September 15, 2021 Share Posted September 15, 2021 4 minutes ago, AimeeTotalHome said: THANK YOU THAT WORKED! Glad it helped. Link to comment Share on other sites More sharing options...
Kbird1 Posted September 15, 2021 Share Posted September 15, 2021 4 hours ago, AimeeTotalHome said: Was there an update that we need to get to access them again? There won't be any updates for X12 now X13 has been released ...... X13 maybe in you Locker though if your SSA was/is Valid Link to comment Share on other sites More sharing options...
DonSteigerwald Posted September 26, 2022 Share Posted September 26, 2022 On 9/15/2021 at 6:45 AM, rgardner said: They are probably stuck on your other screen. Try preferences>reset options>reset side windows Thank you! Your answer helped me as well! :) Link to comment Share on other sites More sharing options...
chiefcraft Posted October 22, 2022 Share Posted October 22, 2022 I have same issue but resetting the side windows didn't work? Link to comment Share on other sites More sharing options...
rgardner Posted October 22, 2022 Share Posted October 22, 2022 1 hour ago, chiefcraft said: I have same issue but resetting the side windows didn't work? If it's not showing up at all that means it is somewhere possibly on another instance of that screen or on a monitor that is no longer connected. If the situation is the same as the OP and resetting side windows doesn't do it then call chief support on monday. Link to comment Share on other sites More sharing options...
ChiefArchJIC Posted November 4, 2022 Share Posted November 4, 2022 Thanks. That worked. Project Browser was not displaying after I had put it on a side screen (running double displays). The instruction you gave brought it back so it could be selected again and appeared again. Also, I noticed other problems when I stretched the Chief Architect Window across both displays. Repositioning the Project Browser or others seemed problematic when the Chief Architect Window was spanning both screens, therefore I developed a practice to return the Chief Architect Window back to only a single display screen, when rearranging the tool bars, or the Project Browser, Library Browser. I appreciate your help. Jim Link to comment Share on other sites More sharing options...
slobalzo Posted February 26, 2023 Share Posted February 26, 2023 I have tried all suggestions and cannot get the library browser to open Link to comment Share on other sites More sharing options...
DBCooper Posted February 27, 2023 Share Posted February 27, 2023 If "reset side windows" doesn't work, then you should call tech support. Link to comment Share on other sites More sharing options...
