mtldesigns Posted September 11, 2021 Share Posted September 11, 2021 (edited) Detailing a kitchen island that has a pony wall on the back side for a raised bar. When I did the wall elevation view, the electrical did not show up (island 1).. I thought "that's weird" because the wall elevation showed the electrical on the full wall. When you uncheck "clip to room", the electrical does appear (island 2). So I did the same for a end view (island 3 and 4) and the same thing happened. It appears it does not recognize a pony wall, until I unchecked the "clip to room". I looked at the settings and this isn't something to set. Any ideas of why (a bug or the new norm)? I honestly don't remember if was the case in X12, and I just worked through it. Thanks in advance. Edited September 11, 2021 by mtldesigns added picture Link to comment Share on other sites More sharing options...
Kbird1 Posted September 11, 2021 Share Posted September 11, 2021 might be a bug as it appears the ignore Railings and Invisible Walls Option is activating even though the box is not checked in your pics. ( make sure Walls>Railings layer is on in that view though ) in the 1st pic I think you maybe seeing just the backsplash, and Countertop on the wall, but not the wall due to the issue.... M. Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 11, 2021 Share Posted September 11, 2021 Not acting in a negative way on my computer, sorry in any version. DJP Link to comment Share on other sites More sharing options...
