ElkRivers Posted September 10, 2021 Share Posted September 10, 2021 Does anyone have any input on what would be the best way to draw this type of eave? I don't want to be fighting the program the whole time. Not sure if I should just draw a standard roof and use polylines to create the extra tall "fascia" or if it should be part of a wall or roof or...? Link to comment Share on other sites More sharing options...
rlackore Posted September 10, 2021 Share Posted September 10, 2021 Maybe adjust the Eave subfascia and fascia settings in the Structure tab: 1 Link to comment Share on other sites More sharing options...
robdyck Posted September 10, 2021 Share Posted September 10, 2021 1 hour ago, ElkRivers said: Does anyone have any input on what would be the best way to draw this type of eave? This will only work where there are no windows or doors!! 1 Link to comment Share on other sites More sharing options...
ElkRivers Posted September 10, 2021 Author Share Posted September 10, 2021 Thanks. I'll give it a try. It will only be on the corners of the house, so I will have to make separate roof planes at the corners. I appreciate the input! Karen Link to comment Share on other sites More sharing options...
MarkMc Posted September 10, 2021 Share Posted September 10, 2021 This kept me amused for a while. Outlined in red- furred thick pony wall (partition wall), bottom is room divider, surface set to match soffit material then applied wall material region (hold off the front edge) Wall thickness determined in elevation to work with fascia height (is 16 and change here) White is 3D molding line (always a PIA) Link to comment Share on other sites More sharing options...
