CharityS Posted September 8, 2021 Share Posted September 8, 2021 I am drawing out an already existing store front. I have done work but its just not exactly how I want it. What would your advise to be creating the zig zag back store front with the full windows?? Thank You! Link to comment Share on other sites More sharing options...
joey_martin Posted September 8, 2021 Share Posted September 8, 2021 Ponywalls 1 Link to comment Share on other sites More sharing options...
rgardner Posted September 8, 2021 Share Posted September 8, 2021 10 minutes ago, joey_martin said: Ponywalls I probably would use this method as well. As an alternative but I think it would be more finicky would be to do regular walls with fixed windows. Corners are going to be a little tricky though which is why I think pony-walls would be much faster. Link to comment Share on other sites More sharing options...
Kbird1 Posted September 8, 2021 Share Posted September 8, 2021 For a few years now I have used a Store Front Wall Type, which is essentially a Wall type similar to "Frame 3 1/2" with the Framing Built and Shown ( turn Wall framing on in all Cameras) and then editing the Framing as needed to make it look like a Store Front, in Plan view, Wall Detail or 3D camera for quick deleting of "Studs". * The Mitre Framing Tool will help clean up Corners... ** best to draw the 1st wall, open it and on the structure Tab at the bottom uncheck Stagger Framing Layers, then pull wall further around. Mick. 2 Link to comment Share on other sites More sharing options...
