Store Front
CharityS
10 minutes ago, joey_martin said:
Ponywalls
I probably would use this method as well.
As an alternative but I think it would be more finicky would be to do regular walls with fixed windows.  Corners are going to be a little tricky though which is why I think pony-walls would be much faster.
For a few years now I have used a Store Front Wall Type, which is essentially a Wall type similar to "Frame 3 1/2" with the Framing Built and Shown ( turn Wall framing on in all Cameras) and then editing the Framing as needed to make it look like a Store Front, in Plan view, Wall Detail or 3D camera for quick deleting of "Studs".
*  The Mitre Framing Tool will help clean up Corners...
** best to draw the 1st wall, open it and on the structure Tab at the bottom uncheck Stagger Framing Layers, then pull wall further around.
image.thumb.png.529ce7cfb79f4583191911ac39727c11.png image.thumb.png.418280cf5de767efe7d8b30dbf79d52f.png
Mick.
  • Like 2
