Rich Text Box Shrinks When Sent to Layout
skoz44
Hi,
In the past few months, I've found a number of layouts that are displaying Rich Text like the box shrunk.  I tend to find it most often on my electrical circuit numbers.  For example, I will have a number of circuits numbers "55", send to layout and everything looks fine.  I then open it and all you see is "5", like the actual box was too small.  If I open and then hit OK, the text goes back to what it should.  I've attached a screenshot where you can see the ones I fixed and the ones that are truncated.
If it matters, I have Auto Height and Auto Width checked, CAD Style Font Sizing, and Rotate with Plan all selected.
Any suggestions as to how to correct this?
Have you perhaps changed computers ?  I think it has to do with a change in screen resolution and Chief seems to not be able to compensate for that quite properly.  With a little searching you should be able to find several threads on the subject but off hand I don't think there is a solution yet other than the one you are using.
Yep , it does sound like the different Resolution Text issue that has been around for a few Versions now at least...
Can't comment on whether it is fixed in X13 , though I have not run into it myself yet , there was a new update last night to x13 though.
Mick
