cementlogic Posted August 16, 2021 Share Posted August 16, 2021 How do you change the default accounting codes in material lists? Link to comment Share on other sites More sharing options...
Solution Kbird1 Posted August 16, 2021 Solution Share Posted August 16, 2021 Chief has these tied to BuilderTrend Codes, but I think you can Double click them to edit them Yep that works.... Link to comment Share on other sites More sharing options...
cementlogic Posted August 16, 2021 Author Share Posted August 16, 2021 Would you look at that! Thank you! Link to comment Share on other sites More sharing options...
gelbuilding Posted October 2, 2021 Share Posted October 2, 2021 Hi Mick, How do we see the codes? My cost code column is blank Link to comment Share on other sites More sharing options...
robdyck Posted October 2, 2021 Share Posted October 2, 2021 3 hours ago, gelbuilding said: Hi Mick, How do we see the codes? My cost code column is blank Link to comment Share on other sites More sharing options...
gelbuilding Posted October 2, 2021 Share Posted October 2, 2021 Thanks Robert. Thats what i did though my column is blank. Link to comment Share on other sites More sharing options...
gelbuilding Posted October 2, 2021 Share Posted October 2, 2021 Hi Robert, Sorry i had two code Columns. Thanks again Link to comment Share on other sites More sharing options...
gelbuilding Posted October 5, 2021 Share Posted October 5, 2021 Can the cost codes be edited? Thanks Link to comment Share on other sites More sharing options...
gelbuilding Posted October 5, 2021 Share Posted October 5, 2021 I see the codes can be changed directly into the material list, though i would like to predefine them. Im setting up with buildertrend though i have my specific codes 1 Link to comment Share on other sites More sharing options...
