Jambruins Posted August 12, 2021 Share Posted August 12, 2021 I am designing a garage with 10' walls but the floor joists will be installed two feet below the top of wall. Basically creating a 2' knee wall for the upper portion of the garage. When I put my stairs in it says they don't meet the floor of the above level. How do I get it so my stairs know the floor joists are 24" lower than the top of wall? I know I can just change the stairs manually but if I do that and select the auto stairwell it won't create the opening in the floor above because it says the stairs don't reach that level. Link to comment Share on other sites More sharing options...
glennw Posted August 12, 2021 Share Posted August 12, 2021 Build a second floor. 1 Link to comment Share on other sites More sharing options...
dshall Posted August 12, 2021 Share Posted August 12, 2021 59 minutes ago, glennw said: Build a second floor. Yep, and to expand on that, on the second floor make it open below and then you can put in a minimal slope roof (1/2:12) 2' below topo 2nd floor walls. 1 Link to comment Share on other sites More sharing options...
Jambruins Posted August 12, 2021 Author Share Posted August 12, 2021 The walls are 10' tall and then the rafters will be on top of the wall with a 12:12 pitch. What should I set my rough and finished ceiling height as for the 2nd floor? I know I will uncheck the flat ceiling option. Link to comment Share on other sites More sharing options...
dshall Posted August 12, 2021 Share Posted August 12, 2021 1 Link to comment Share on other sites More sharing options...
rgardner Posted August 12, 2021 Share Posted August 12, 2021 2 hours ago, dshall said: on the second floor make it open below and then you can put in a minimal slope roof (1/2:12) 2' below topo 2nd floor walls I think this was an old technique to accomplish what you are trying to do. What will work for you is to select the lower walls and in the structure panel choose the option to hang the floor system from this wall, as well as the other options you may want to do. Then you can set your 2nd floor walls to Balloon through Floor below. The result you get after auto-framing everything is this: Link to comment Share on other sites More sharing options...
Jambruins Posted August 12, 2021 Author Share Posted August 12, 2021 awesome, thank you. I will try it out. Link to comment Share on other sites More sharing options...
glennw Posted August 12, 2021 Share Posted August 12, 2021 Ryan, Your rafter overhangs look like they are being cut off by the wall. Link to comment Share on other sites More sharing options...
