Possible Bug
joey_martin
I have confirmed in X12 that this works properly, but in X13 not so much.
I need to lower the ceiling of the porch....
But when I do, it's now dragging the entire floor down with it. Auto Roofs is now turned off, and I can't lower the porch ceiling without changing the entire floor....this is a BIG problem.
Anyone else hitting this problem in X13?
I just drew a very simplified version of what you have and it worked to lower the ceiling by dropping the Absolute Ceiling Elevation of the room.
No apparent issues.  Could you pull back from that inside corner and see if that is the issue ?
On 8/8/2021 at 8:56 AM, joey_martin said:
I was able to narrow it down to the cantilevered area. Once I pulled it back from there it worked as I wanted.
I sent a bug report in along with the plan.
Not sure what you mean by "cantilevered area" since I haven't seen the plan, but....
It was also the case in X12 that whenever a room extended underneath a cantilevered portion of the room above, adjusting the ceiling height of the lower room would also adjust the floor above.
