EngelsmaHomes Posted July 26, 2021 Share Posted July 26, 2021 Hi all, I noticed small angled lines that are commonly used to indicate glass on drafting drawings on elevations from Chief (see example photo attached). Is there a way to turn those 'ON' with a glass or reflective material? Or are those being added manually? Thanks for the help! Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 26, 2021 Share Posted July 26, 2021 They can be drawn manually using short CAD lines and they are also found as a CAD block in the Library Browser under "CAD Blocks - Designer Blocks - Reflection". They are manually doe either way and not by way of any "check box" in a dialog. DJP Link to comment Share on other sites More sharing options...
Adam_Gibson Posted July 26, 2021 Share Posted July 26, 2021 I recommend that you make a suggestion in the Wishlist forum. The more who request it, the more likely it is to be implemented. It would be quite the time saver when doing large elevations. Link to comment Share on other sites More sharing options...
rgardner Posted July 26, 2021 Share Posted July 26, 2021 This can be done with a custom hatch pattern. I don't have the need for it personally so have never purchased it but I believe that @Alaskan_Sonuses and previously recommended hatchkit.com.au/ (only for PC). Then create your glass that you like to use with that pattern type... 1 Link to comment Share on other sites More sharing options...
