How do I create a living wall of plants?
I am using Chief Architect Premier X13, and I want to create a living wall for a client's office space. I've tried building a frame and adding plants to the frame, but I cannot rotate the plants on the y-axis in order for them to be "planted" on the wall. Is there any other technique or tip I can apply to creating this wall? Any help is greatly appreciated!
You may do better with a photograph of an existing living wall applied as a material unless it is a totally custom design.
You could likely do a setup with 3D plants but it is very much a computer resource hog.
Just now, MicaGlassDesigns said:
Thanks. I'll give that a try. It seems like it will take significantly less time, too.
Yes it will for sure if it will satisfy the client.  You can apply the material directly to the entire wall or place a p-solid skin on a segment of the wall.
I originally thought that the best way would be to use 3D plants (2D plants would look pretty dicky) with either the Garden Bed tool or the Distribution tools because both these tools make it easy to automatically distribute objects.
The idea would be to then to create a symbol and rotate to vertical.
There was just too many surfaces and I gave up because it was taking too long on my machine.
Someone else may have more luck with a faster machine.
Why do just a boring old flat wall? :)
Or you could crop this if you want to use as a picture.
Not pretending to know the best overall approach, but if you find the plants you want to use, you can add the following method to your toolbag of potential solutions...
You can open the desired Plant Image File in a photo editor, rotate the image, and then use that new image.  You just need to:
  1. Find your desired plant
  2. Open the Plant Image Specification dialog box
  3. Find where the Image File is located on your computer
  4. Open that file
  5. Edit the image to rotate as desired
  6. Save As a new PNG file
  7. Use that new PNG file for your Image File
In Windows, the main keys are that you have to:
A.  Open the zipped folder before you can access the image file
B.  Paste the image file name by adding a \ instead of #zip:
Example:
Full Image File Name ---->  C:\ProgramData\Chief Architect Premier X13\Referenced Files\CorePlantFiles.zip#zip:Clematis ternifolia2.png
First paste this into the Windows Explorer Address Bar ---->  C:\ProgramData\Chief Architect Premier X13\Referenced Files\CorePlantFiles.zip
Once that folder is opened, add a backslash and paste the file name in after it, like this ---->  C:\ProgramData\Chief Architect Premier X13\Referenced Files\CorePlantFiles.zip\Clematis ternifolia2.png
    29829
    MeganB
    MeganB
  • Similar Content
    • By divreig
      Anyone know how to change label text size? I am working on a large building and the layout scaling is 1/32". The labels are too small and cant be read. I cant find options for text size all the label panel, all it has that box that says use default, that I can check and uncheck. But don't know where to edit this default size or the individual label text size.
    • By thewell
      Does anyone have a site to OBTAIN MORE PLANTS THAN IN THE CHIEF CATALOGS?  I do a lot of landscape design - and really could use MORE PLANTS ...........
      2nd question - EASIEST WAY TO ALTER THE 2D PLANT IMAGE IN COLOR (versus most plant images in 2d are black/white) ... AND STORE THE 2d symbol along with the plant etc
    • By WhistlerBuilder
      I have a project where I have some plants displaying improperly. Plants that are physically behind another plant are showing in front of it.
      The plants that are having the problem are all elevated off the "terrain" and in planter boxes. Originally I had them located in a different floor, then moved them to the layer with all the other plants and the clipping issue went away. Then a few days later I opened the project back up and the problem was back.
      I had the plants listed in a separate layer origionally as well. I switched them back to the basic "plant" layer and I am still getting the problem.
      Has anyone else encountered this? Any tips for fixing it? I have a presentation to give soon on this project and I am severely limited in the camera angles I can show because of this problem.
    • By Kriska
      Hello,
      I guess it's time to ask this question because I cannot figure out why the program does this. Plants in the background show to be in front of foreground trees. I cannot seem to bring the trees forward and push the plants to a lower layer. Almost as if the trees are transparent. If anyone has this answer it would be much appreciated thank you.
    • By jcaffee
      Create 3D tree/plant clusters (I use 5-7 trees for a performance vs. aesthetic balance) where the items are variable heights, and turn the cluster into a symbol.
      Then, select the symbol using the Distributed Region tool. Set spacing with a good overlap, and Random Angles.
      The results look like this...
