Elevation not showing Cylinders
ACADuser
12 hours ago, Kbird1 said:
same layerset in both views?
backclipped view?
They are probably there but not displaying the edge lines. He'd see them if his color was on. Polyline solids can have the same behavior. You'll be able to see the lines from either x or y but not both, unless you rotate them 45 degrees. The same issue applies to selecting those solids or cylinders in a  section view for a drag-type height adjustment.
Draw a circle, convert to polyline solid. Take a section view from the front and the left. See if you can select it from the left view to adjust it's height.
And to be silly, in those section views, set the backdrop to white, turn off the grid and turn off the color.
This could also be a bug related to disappearing edge lines for rounded surfaces. @ACADuser could try F12 to see if that helps, or he may need to create a cad detail from the view, then copy-paste the needed lines back into the elevation view.
Good to know , not sure I have run into that issue....
I know there is an issue in elevation for cabinet hardware for example , unless it is somehow related to that?
I have had to that recently myself to get outlines of Symbols properly in elevation....
Yesterday I had the same issue with exterior stair handrails (using a curved profile) so I don't think that particular problem is only in relation to hardware.
I will have to keep my eyes open in X13 as a lot of my work currently is still in X12 , but  I am now starting new projects in X13.
