HannahKucerova Posted July 14, 2021 Share Posted July 14, 2021 Did a quick browse/search and don't see where anyone else has posted about this. Has anyone run into imported materials not stretching properly (or as they previously did in X12 and backwards) in the new X13? I import a lot of custom countertops materials and previously when the material was set to stretch to fit, it would spread out nicely and create a fairly realistic interpretation of the material. In X13, the same material now has multiple directional face lines when on a surface that has a hole in it (i.e. a countertop with sink, etc.). I do remember seeing this same phenomenon in prior versions when I would use a custom tile material on a floor (for like a shower, but I always would undo the stretch to fit option because in those instances I *wanted* the repeating pattern.), but never on a countertop. The attached pictures are the same custom countertop size, sink, faucet and material...just one is x12 and one is X13. Both are using the Custom Countertop tool. I'm pretty sure this has to do with some of the new rendering coding, so maybe it is proper for X13, but I am hoping there is a way to get around it as it does not look good in presentations. Am I missing something easy? Link to comment Share on other sites More sharing options...
kwhitt Posted July 14, 2021 Share Posted July 14, 2021 47 minutes ago, HannahKucerova said: Did a quick browse/search and don't see where anyone else has posted about this. Has anyone run into imported materials not stretching properly (or as they previously did in X12 and backwards) in the new X13? I import a lot of custom countertops materials and previously when the material was set to stretch to fit, it would spread out nicely and create a fairly realistic interpretation of the material. In X13, the same material now has multiple directional face lines when on a surface that has a hole in it (i.e. a countertop with sink, etc.). I do remember seeing this same phenomenon in prior versions when I would use a custom tile material on a floor (for like a shower, but I always would undo the stretch to fit option because in those instances I *wanted* the repeating pattern.), but never on a countertop. The attached pictures are the same custom countertop size, sink, faucet and material...just one is x12 and one is X13. Both are using the Custom Countertop tool. I'm pretty sure this has to do with some of the new rendering coding, so maybe it is proper for X13, but I am hoping there is a way to get around it as it does not look good in presentations. Am I missing something easy? I have run into that, but it usually clears up when I make it one large custom countertop. It is happening to me when the cabinet countertops are segmented. You might try ticking "global mapping" under the texture tab in the materials dialog box. Link to comment Share on other sites More sharing options...
Christina_Girerd Posted July 14, 2021 Share Posted July 14, 2021 I just tried it and can confirm there is a difference in behavior between x12 and x13 in how a sink placed into a single countertop impacts the "stretch to fit" counter material. (BTW, I tried global mapping and it didn't make any difference.) I used the "Garden of Irises" painting as it showed very clearly how the texture in x13 is being stretched oddly at each corner of the sink. I put this on a single cabinet that I enlarged to show the issue. I will submit a bug report. 3 Link to comment Share on other sites More sharing options...
Christina_Girerd Posted July 14, 2021 Share Posted July 14, 2021 Chief answered the report and said they have reproduced the issue and logged it. 1 Link to comment Share on other sites More sharing options...
HannahKucerova Posted July 14, 2021 Author Share Posted July 14, 2021 Thank you Christina! I am sad it is a real thing but also glad I haven't lost more of my mind that previously thought... Link to comment Share on other sites More sharing options...
robdyck Posted July 14, 2021 Share Posted July 14, 2021 I've noticed that global symbol mapping has not worked correctly with some exterior materials. Sounds like the same type of problem. In this case it's the pattern that won't hold the line. This is all the same material. Link to comment Share on other sites More sharing options...
ChiefRoeser Posted August 11, 2021 Share Posted August 11, 2021 I am having the same issue with custom countertops. Has anyone found a solution or workaround? Attached 2 files from x13. One with the cooktop as a symbol (texture looks good). 2nd image is with the cooktop placed as an object "in" countertop. My assumption is that when the program creates a "hole in countertop", something doesn't resolve the new, custom countertop, to accept the texture??? Any help would be appreciated. Thanks! Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 11, 2021 Share Posted August 11, 2021 1 hour ago, ChiefRoeser said: Has anyone found a solution or workaround? For now, I would suggest you increase the Scale of your Texture instead of using Stretch to Fit, and make sure to send in to tech support if you care to see it fixed. 1 Link to comment Share on other sites More sharing options...
ChiefRoeser Posted August 12, 2021 Share Posted August 12, 2021 20 hours ago, Alaskan_Son said: For now, I would suggest you increase the Scale of your Texture instead of using Stretch to Fit, and make sure to send in to tech support if you care to see it fixed. Thanks. I did that and it seems to work on the island, but the corner base cabinet is still giving me problems. I believe Chief is aware of the issue. Just wondering if there was a fix or update. On 7/14/2021 at 12:03 PM, Christina_Girerd said: Chief answered the report and said they have reproduced the issue and logged it. Link to comment Share on other sites More sharing options...
