Can you add a hatch pattern to a door slab?
Charles
I don't think so without an ingenious workaround.  You could use a doorway and then an independently places door symbol with a custom 2D cad block but by the time you go to that much trouble you might as well do it in cad the way it was likely done originally. ;)
If this is something that you would use quite often and is always the same size and you don't want a label for, and......
You could use the Label to display a custom Description in Object Information.
Save to the library for future use.
Pretty creative solution there good sir.
