Charles Posted June 19, 2021 Share Posted June 19, 2021 I'm trying to match existing drawings that show a hatch pattern on the door slab (without using a hatched cad rectangle)? Thanks, Charles Link to comment Share on other sites More sharing options...
Chopsaw Posted June 19, 2021 Share Posted June 19, 2021 I don't think so without an ingenious workaround. You could use a doorway and then an independently places door symbol with a custom 2D cad block but by the time you go to that much trouble you might as well do it in cad the way it was likely done originally. Link to comment Share on other sites More sharing options...
Charles Posted June 19, 2021 Author Share Posted June 19, 2021 Thanks Chopsaw, I did'nt think it could be done (easily), but I though I would ask. I appreciate your response Link to comment Share on other sites More sharing options...
glennw Posted June 20, 2021 Share Posted June 20, 2021 If this is something that you would use quite often and is always the same size and you don't want a label for, and...... You could use the Label to display a custom Description in Object Information. Save to the library for future use. 1 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 20, 2021 Share Posted June 20, 2021 1 hour ago, glennw said: If this is something that you would use quite often and is always the same size and you don't want a label for, and...... You could use the Label to display a custom Description in Object Information. Save to the library for future use. Pretty creative solution there good sir. Link to comment Share on other sites More sharing options...
