DianeP Posted June 8, 2021 Share Posted June 8, 2021 Can anyone help me with how can I get the 6" siding wall to line up with the exterior side of the concrete on the ICF wall? Link to comment Share on other sites More sharing options...
Chopsaw Posted June 8, 2021 Share Posted June 8, 2021 Link to comment Share on other sites More sharing options...
rgardner Posted June 9, 2021 Share Posted June 9, 2021 Move your air gap and house wrap to the exterior not the main layer, then align at main layer outside. Link to comment Share on other sites More sharing options...
DianeP Posted June 9, 2021 Author Share Posted June 9, 2021 15 hours ago, Chopsaw said: Thanks for giving me ideas to look at, but the exterior choice lines the board and batton up with the exterior of the brick. I am trying to have the exterior of the 2x6 wall line up with the exterior of the concrete in the ICF wall, which is what I have been told is the way this wall would need to be built. Any other ideas? Link to comment Share on other sites More sharing options...
DianeP Posted June 9, 2021 Author Share Posted June 9, 2021 14 hours ago, rgardner said: Move your air gap and house wrap to the exterior not the main layer, then align at main layer outside. I tried your idea. It seemed so promising, but the airgap moved to the exterior acted like a thick wall and interfered with the roofs that I had (see picture) such that I couldn't drag the roof grips over to close the space. It would just revert back to its original position because it thought the airgap was part of the wall. The airgap also put another type of material on my drawing instead of the board and batten. I tried to change the material for the airgap to board and batten, but it didn't work. Link to comment Share on other sites More sharing options...
Chopsaw Posted June 9, 2021 Share Posted June 9, 2021 19 minutes ago, DianeP said: Thanks for giving me ideas to look at, but the exterior choice lines the board and batton up with the exterior of the brick. I am trying to have the exterior of the 2x6 wall line up with the exterior of the concrete in the ICF wall, which is what I have been told is the way this wall would need to be built. Any other ideas? 1 Link to comment Share on other sites More sharing options...
rgardner Posted June 9, 2021 Share Posted June 9, 2021 21 minutes ago, DianeP said: I tried your idea. It seemed so promising, but the airgap moved to the exterior acted like a thick wall and interfered with the roofs that I had (see picture) such that I couldn't drag the roof grips over to close the space. It would just revert back to its original position because it thought the airgap was part of the wall. The airgap also put another type of material on my drawing instead of the board and batten. I tried to change the material for the airgap to board and batten, but it didn't work. Sorry I was doing that on my phone so no pics. But no air gap for that and especially not on the outside of the exterior layer, I was saying to move the airgap and brick and everything to the exterior layer, make your main layer of the concrete and the framing layer be in your main layer only and everything on the outside of that in the exterior layer, (i.e. Interior layer: drywall, main layer, fir framing, exterior layer: osb, house wrap, board and batten.) Like Chop is showing above. BTW your cursor says you need to rebuild your terrain. 1 Link to comment Share on other sites More sharing options...
DianeP Posted June 11, 2021 Author Share Posted June 11, 2021 On 6/9/2021 at 10:25 AM, Chopsaw said: Thanks! This got me what I needed. Always appreciate your great help!!! Link to comment Share on other sites More sharing options...
