Room Divider
Ed_Orum
They are not the same.  But what does a ceiling height have to do with a room area that is defined at the floor level?  Or is it just the way Chief think the world should be?
Lane
Chief changes the wall so that it can provide a usually appropriate vertical structure at the height change.  When you don’t want a vertical wall at the height change and would prefer to see a single line, I recommend using a Custom Wall Type.  Just copy the OOB Room Divider wall type and set the thickness to .01”.  Name it something like MY Room Divider.  Because the wall already technically has a thickness, Chief won’t change it, and because the wall is nothing more than a single layer Air Gap, it won’t provide anything at the vertical transition areas.
  • Like 2
