MAP6933 Posted May 18, 2021 Share Posted May 18, 2021 Any helpful material/videos or examples that I can learn from to create the blueprints for the contractor? 1 Link to comment Share on other sites More sharing options...
Chrisb222 Posted May 18, 2021 Share Posted May 18, 2021 https://www.chiefarchitect.com/videos/playlists/105/layout-construction-documents.html 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted May 18, 2021 Share Posted May 18, 2021 https://www.chiefarchitect.com/products/samples.html 1 Link to comment Share on other sites More sharing options...
Electromen Posted May 19, 2021 Share Posted May 19, 2021 We made Blueprints in college back in 1973. The method was obsolete even then. Invented in 1842, blueprints were truly Blue The drawing to be copied, drawn on translucent paper, is placed against paper sensitized with a mixture of ferric ammonium citrate and potassium ferricyanide. The sensitized paper is then exposed to light. Where the areas of the sensitized paper are not obscured by the drawing, the light makes the two chemicals react to form blue. The exposed paper is then washed in water. This produces a negative image, with the drawing appearing in white against a dark blue background. Link to comment Share on other sites More sharing options...
Chrisb222 Posted May 19, 2021 Share Posted May 19, 2021 1 hour ago, Electromen said: This produces a negative image, with the drawing appearing in white against a dark blue background. Yeah, I've been wanting to print off a set in negative with blue background. When I did a takeoff on the ink required I changed my mind Link to comment Share on other sites More sharing options...
