crosscutter55 Posted May 15, 2021 Share Posted May 15, 2021 I stared a drawing & made a big mistake !! I started drawing it on page zero . All the info on page zero i do not want on page one , is there anyway I can fix this This was a sub division plan i had all the lots , roads , tax map #s , owner name , and address #s on page zero . I want to have another page / page 1 without the lots , tax map , and address # s & just the roads . Any help is appreciated I am using x10 UNFORTUNATLY I DID THIS IN A LAYOUT , I OPENED A LAYOUT & STARTED USING BOXES , It says i can not open another layout Link to comment Share on other sites More sharing options...
Kenoeightspot Posted May 15, 2021 Share Posted May 15, 2021 Copy and paste on page 1 then delete info on page 0 1 Link to comment Share on other sites More sharing options...
richoffan Posted May 15, 2021 Share Posted May 15, 2021 You could group select all your layout boxes on page 0, open the dialogue box, go to line style and change the layout page in that panel 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 15, 2021 Share Posted May 15, 2021 On 5/15/2021 at 3:19 AM, Kenoeightspot said: Copy and paste on page 1 then delete info on page 0 Expand ...better yet, CUT and then Paste Hold Position. Link to comment Share on other sites More sharing options...
crosscutter55 Posted May 15, 2021 Author Share Posted May 15, 2021 I called up a diffrent sheet size in a layout when setting up some defaults & instead of going to the plan window i had a senior moment & just started plotting stuff in the layout file .If it was in a plan file i wouldnt have this issue I can redo the drawing but it would be easier having page 1 & 2 in x10 Worst part is i dont use chief everyday How are you doing eric i hope you & yours are okay in this crazy world !! Link to comment Share on other sites More sharing options...
richoffan Posted May 15, 2021 Share Posted May 15, 2021 I just tried this 'cause never had to do in reverse... You can select items drawn on sheet 0 / copy / open a new plan / edit>paste (it'll be really small) just zoom in - You should be able to send to layout from there.... did in X12 but sure edit>paste was in X10 Link to comment Share on other sites More sharing options...
ACADuser Posted May 16, 2021 Share Posted May 16, 2021 Wouldn't this work? Exchanging Floors Select Build> Floor> Exchange With Floor Above or Exchange With Floor Below to swap the Current Floor with the floor above or below. The floor that was moved becomes the Current Floor at its new location. You can easily move a floor up or down several floors by using either one of these buttons repeatedly. Link to comment Share on other sites More sharing options...
