ceiling hole in basement for window
ChiefuserMathews
6 minutes ago, ChiefuserMathews said:
Hi Joey, thank you for your reply. What does the wall have to do floor above? The hole is cutting through the floor slab
What Joey is saying, is not to use a hole, but rather create a small room on the floor above the window so that you can specify a shallower floor framing thickness.
38 minutes ago, ChiefuserMathews said:
oh ok thank you
This same method can be helpful when you have headroom issues at a set of stairs. As shown in Joey's example, you'll only get vertical transitions. So if you want an angled transition, you'll need to make the 'room' large enough so you can get a small piece of drywall and hammer it through your screen into the Chief model...I mean use a p-solid to model the angled transition.
