DamienT Posted April 5, 2021 Share Posted April 5, 2021 Is there a way to overlay floor sheets so you can line up different floorplans on different sheets eg. Have the electrical plan positioned exactly in the same place as the main floorplan sheet, or line up the upper level plan sheet with the lower level on another sheet? Like the reference tool on the plan detail, but on the sheets Link to comment Share on other sites More sharing options...
GeneDavis Posted April 5, 2021 Share Posted April 5, 2021 What have you tried? How precise must alignment be, and how can you proof it? Link to comment Share on other sites More sharing options...
conwaynorth1 Posted April 5, 2021 Share Posted April 5, 2021 I'm sure there's lots of answers to this question. The way I do it is by putting a temporary point on the template page and then point to point move a corner of the building to that point on every page. Link to comment Share on other sites More sharing options...
justmejerry Posted April 5, 2021 Share Posted April 5, 2021 If you are using Plan Views very easy to do. Place your first one where you want it and then copy and hold position for next page. Once you place open the layout box and change your floor and plan view to suit. Link to comment Share on other sites More sharing options...
Chrisb222 Posted April 5, 2021 Share Posted April 5, 2021 1 minute ago, justmejerry said: If you are using Plan Views very easy to do. Place your first one where you want it and then copy and hold position for next page. Once you place open the layout box and change your floor and plan view to suit. That's what I do. But just to elaborate, position the first view how you want it on the sheet, then copy that layout view. Go to the other sheet, and use Paste/Hold Position to paste the previous view exactly where it is on the previous sheet. Then, open that view and change the floor and/or the Saved Plan View or Current Default Set. Link to comment Share on other sites More sharing options...
