Shelves not going into wall niche issue.
Ak49GCD
Hey everyone, I've been searching for an answer on this issue but can't figure it out. The shelves are not going into the wall niche, is there any specific reason as to why? I've adjusted the sizes both width and depth thinking maybe they were too large to go into the niche (even though the shelves are 1/2" smaller in each dimension compared to the niche.) Thanks for any advice.
  • 3 years later...
An alternative is to use a fixture symbol set into wall You can use a cabinet, orignal at left, then fixture made from cabinet, then that inserted into a niche.
OR you can set shelves to insert into  a wall niche last on right.. Advantage is you have more control over the placement and or number of shelves AND important if you need framing.
If using shelves make it oversize, place in plan, set height for one, resize as need. Transform replicate to add more shelves.
5 hours ago, AmberDawn said:
Same issue here!
Im using the command key and its still not working!
Might be worth Checking your HotKeys if its not working, has someone changed the Default ?
