BruceKC Posted March 25, 2021 Share Posted March 25, 2021 Is it possible to use a polyline or some other method than walls or room dividers to define a room? When I put an invisible wall next to a rail and label the enclosed area "Open Below", the invisible wall covers up part of the opening in plan view and that doesn't look very good. thanks all. Link to comment Share on other sites More sharing options...
BruceKC Posted March 25, 2021 Author Share Posted March 25, 2021 Here is the plan view and the 3d overview Link to comment Share on other sites More sharing options...
Chrisb222 Posted March 25, 2021 Share Posted March 25, 2021 1 hour ago, BruceKC said: Here is the plan view and the 3d overview Yeah you need a really thin room divider wall there. You can't make it 0" but you can make it .01" the program will show it as 0 but it will work Then line it up right over the edge of the stairs, put it on its own layer, make the line style and weight for that layer the same as your stairs, and tun off the other Invisible Walls layer Link to comment Share on other sites More sharing options...
BruceKC Posted March 25, 2021 Author Share Posted March 25, 2021 Thanks! I'll give that a shot, I really appreciate it! Link to comment Share on other sites More sharing options...
BruceKC Posted March 25, 2021 Author Share Posted March 25, 2021 Hi Solver, if I do that, the wall is actually still there, so it just blanks out an area anyway. Link to comment Share on other sites More sharing options...
Chrisb222 Posted March 25, 2021 Share Posted March 25, 2021 2 minutes ago, BruceKC said: Thanks! I'll give that a shot, I really appreciate it! Sure. I used to struggle with showing the top line of the stairs for that reason. Even with a thin wall if you turn off display of invisible walls it still covers the stair line. If you move the wall out a fuzz it throws the model off. I started doing this trick and it works great, and keeps the 3D intact. Link to comment Share on other sites More sharing options...
Chrisb222 Posted March 25, 2021 Share Posted March 25, 2021 Just now, BruceKC said: Hi Solver, if I do that, the wall is actually still there, so it just blanks out an area anyway. Yep Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 25, 2021 Share Posted March 25, 2021 I'm curious as to why you are having this problem. The "Create Stairwell" tool should handle this without you needing to add any invisible or divider walls. Can you post the plan file so we can really help? Link to comment Share on other sites More sharing options...
BruceKC Posted March 25, 2021 Author Share Posted March 25, 2021 Hey everyone, thanks so much for your help. I didn't use create stairwell, I defined it with walls and labeled the inner space as "Open Below", so maybe I should investigate the create stairwell next time? Sorry for all my questions, we're just trying to migrate from Autocad Architecture to X12. We originally bought X12 just to use it to create 3D renderings of the front elevation, but once we started looking at the program, we were kind of "blown away" with all the improvements (We had X1). So now, we're trying to learn as much as we can as quickly as we can. We're also amazed at Chief support, and even moreso with the users like all of you who have jumped in to help. It's been an amazing start for us thanks to all of you. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 25, 2021 Share Posted March 25, 2021 Just to help clarify...The Auto Stairwell tool is a good tool and can be used to help speed up the process, but it just places walls for you and automatically defines the Room as Open Below. Again, it’s still places walls/railings and defines a room so it’s not doing anything you can’t manually do yourself. It looks like maybe you’re just missing a wall as Eric alluded to. Link to comment Share on other sites More sharing options...
