bdillard Posted February 24, 2021 Share Posted February 24, 2021 Hello, I'm getting some great help here. I'm at the point I'm learning for the sake of learning as I find this interesting. I'm trying to create the correct external wall structure which (in my case) would be fiberboard siding over a rain-screen, over house wrap over Zip-R9 with 2x6 (T-Stud or LVL) at 24 OC with 2" of closed cell with 4" of rock wool and possibly some poly before the sheetrock. I watched a video on it and don't seem to be getting it right. I can't find rain screen (may go by another name e.g. lap bands or something else.) and haven't found the T-stud or LVL or styro or poly sheeting. Don't beat yourself up trying to help if this is too hard to explain to a newbie, I'm just curious. Link to comment Share on other sites More sharing options...
GeneDavis Posted February 24, 2021 Share Posted February 24, 2021 Think of the rainscreen cavity as a framing layer. You define the width of the "studs," their spacing, and material. 1 Link to comment Share on other sites More sharing options...
bdillard Posted February 24, 2021 Author Share Posted February 24, 2021 Thanks! I'm working on it - do I specify here that I want closed cell and rockwool on the interior? I'm wondering how I specify I want it between the framing timber. If I go to the main layer and add anything it increases the thickness of the wall but I want it between the framing. I'm sure the answer is in front of me but I don't see it. I'm not sure if I should do this but I think this is close. I'm just manually typing these into the default. I'm not sure how to put in the measurement for closed cell spray insulation. Unfortunately even after I make those changes, when you click on an exterior wall of the same type it doesn't show those components. Link to comment Share on other sites More sharing options...
SNestor Posted February 25, 2021 Share Posted February 25, 2021 On 2/24/2021 at 2:10 AM, bdillard said: Hello, I'm getting some great help here. I'm at the point I'm learning for the sake of learning as I find this interesting. I'm trying to create the correct external wall structure which (in my case) would be fiberboard siding over a rain-screen, over house wrap over Zip-R9 with 2x6 (T-Stud or LVL) at 24 OC with 2" of closed cell with 4" of rock wool and possibly some poly before the sheetrock. I watched a video on it and don't seem to be getting it right. I can't find rain screen (may go by another name e.g. lap bands or something else.) and haven't found the T-stud or LVL or styro or poly sheeting. Don't beat yourself up trying to help if this is too hard to explain to a newbie, I'm just curious. I don't think you'll get exactly what you want from Chief...but you can get close: See attached pics...hope they give you some idea on how you could create a wall type that is close to what you want. 1 Link to comment Share on other sites More sharing options...
kMoquin Posted February 25, 2021 Share Posted February 25, 2021 You may need to create custom materials if the ones you want aren't in the library. (ie the T-Stud or Rockwool) Steve has you covered on the strapping. Sometimes I just use "Opening (No Material)" for a rainscreen I simulate Zip-R with the OSB material and the Insulation Foam material. 1 Link to comment Share on other sites More sharing options...
bdillard Posted February 25, 2021 Author Share Posted February 25, 2021 Thanks Everyone! Link to comment Share on other sites More sharing options...
