crazy roof
winterdd
can anyone tell me what i am doing wrong on the left side gables?? it's a mess and needs cleaning up/roof planes joined. attached is my cad pdf and the plan file. i have been fighting this for a few days. this one is getting me stumped. it is done in x12.
home characteristics:
all rooms have 9' ceilings
front porch is 10' ceiling
back porch is 9' ceiling
highest ridge is 23'-10"
roof pitches are 10/12
dormer pitch is 3/12
porch pitches are 4/12
Harris_Ward.plan
11 hours ago, ChiefUserBigRob said:
you totally rocked that! was it just a matter off connecting roof planes or did i have wall properties messed up? (i.e gable walls)
thanks man!
it was just a matter of connecting, breaking and reconnecting some of your roof planes. and adding attic walls.
813753741_GableEnds.thumb.jpg.f4a2083e8a1985d914ec83bc171f1652.jpg138863078_GableEndsWallCap.thumb.jpg.63556666a6c944c620677bf427b5cb75.jpg
I would also make sure that you don't have pony walls as interior gable ends, remove wall caps from attic walls and define the siding for the walls as a wall type and not paint the siding in a wall type with a different siding.
@ChiefUserBigRob -
I made some edits to your plan. Made a few minor changes. I noted the things I changed on the plan. Hope some of it helps you...
2102211160_BigRobHouseElev.thumb.png.0133569e39a68065e2e6d53aa722b3c6.png  120796190_BigRobHouseRoofPlan.thumb.png.915076d1df6e339509aeba7432f3c9cc.png
Harris_Ward-BigRob Fix Plan.plan.zip
ALSO...The Chief "residential" plan template is a nice start...and it's great that they provide this template with some "saved plan views"...however, most of the layer sets attached to these plan views need some big help.
I'd suggest to everyone using this template to start with the "roof plan" view...and turn off these layers; "gutters" and "overhang".
Also...change the roof plane layer to "solid" line type and make it a bold color and at least 50 in the line width.
Also...in defaults change the sun to "always follow camera"...
And...in all camera views...lower the setting for "ambient occlusion" to at least 40. (default is 100...)
And...I'd set the number of "lights" to 100...default is 20
I'd make a number of other changes to...but this is a good start.
guys, to further complicate this home, it has a false ceiling. the living is vaulted all the way from the kitchen to the fireplace below two different height gables. my problem i ran into from day one is the highest gable coming down into the living space. i ballooned thru ceiling above but nothing. it has to be on top of the ceiling planes i manually created to close off the gable at attic level. i am not grasping these attic walls on this home......arghh. plan
attached an dupdated.
dormer also has to be functional and open to living space.
Harris_Ward1.plan
