Hammer7 Posted February 3, 2021 Share Posted February 3, 2021 I'm trying to mull these doors and windows properly. Is there a proper training video for this type of procedure? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 3, 2021 Share Posted February 3, 2021 It's pretty much trial and error. I would do it as follows: Make sure the two side-lights are exactly the same height as the door Mull those three together - maybe without casings Make sure the transom is exactly the same width as the result from step 2 Mull those two together - again, maybe without casings Add Casings to the final mulled unit Basically, I don't like the way Chief handles mulled units with casing on individual parts. I find it's usually better to just add the casings, etc to the final mulled object. 1 1 Link to comment Share on other sites More sharing options...
Hammer7 Posted February 3, 2021 Author Share Posted February 3, 2021 So simple but so helpful, thank you! Link to comment Share on other sites More sharing options...
Hammer7 Posted February 3, 2021 Author Share Posted February 3, 2021 now I'm trying to get rid of this interior threashold ... 25 Riverview .pdf Link to comment Share on other sites More sharing options...
ericepv Posted February 3, 2021 Share Posted February 3, 2021 Open the DBX for your door and go to the 'Casing' tab, uncheck 'Use Sill/Threshold'. Link to comment Share on other sites More sharing options...
Hammer7 Posted February 4, 2021 Author Share Posted February 4, 2021 Thank you, but there is no 'Use Sill/Threshold' in the DBX that pops up. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 4, 2021 Share Posted February 4, 2021 You will need to "TAB" to the "Door". Link to comment Share on other sites More sharing options...
ericepv Posted February 4, 2021 Share Posted February 4, 2021 Did you got to the "Casing" section? (3rd choice on the menu on the left side of the DBX) Another thought, if this is a mulled unit (Architectural Block), you may need to ungroup it and select the door individually. Link to comment Share on other sites More sharing options...
Hammer7 Posted February 4, 2021 Author Share Posted February 4, 2021 yes, it is a mulled unit, thank you! Link to comment Share on other sites More sharing options...
ericepv Posted February 4, 2021 Share Posted February 4, 2021 Did that work for you? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 4, 2021 Share Posted February 4, 2021 4 minutes ago, Hammer7 said: yes, it is a mulled unit, thank you! Select the mulled unit and then "Tab" until you have the door. You can then edit it to remove the Sill. Link to comment Share on other sites More sharing options...
Hammer7 Posted February 4, 2021 Author Share Posted February 4, 2021 No, none of it works yet, it seems as if there is a casing appearing horizontally at the floor running through the subfloor 25 Riverview dooor .pdf Link to comment Share on other sites More sharing options...
ericepv Posted February 4, 2021 Share Posted February 4, 2021 That looks like a door sill. Try selecting the piece in question and check to see what layer it's in. Link to comment Share on other sites More sharing options...
