ChiefuserMathews Posted January 27, 2021 Share Posted January 27, 2021 Hello, do we have batten board symbol in CA as wall type as shown in the section attached? Link to comment Share on other sites More sharing options...
ChiefuserMathews Posted January 27, 2021 Author Share Posted January 27, 2021 17 minutes ago, solver said: What "batten board" are you referring to? as in the attached image. when I use the siding 6 wall type and take a section, I get straight line for the sidings. I need the horizontal siding. Hope this image helps Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 27, 2021 Share Posted January 27, 2021 This has been addressed multiple times on this forum for years. Chief Users have created numerous solutions for this siding type, take a look. DJP Link to comment Share on other sites More sharing options...
Kbird1 Posted January 27, 2021 Share Posted January 27, 2021 4 hours ago, ChiefuserMathews said: Hello, do we have batten board symbol in CA as wall type as shown in the section attached? It not to difficult to do you own cross section through a single board , figure out the Tilt on it and then multi-copy it up the wall every 6" MHD_6 in Exp. Lap Siding CAD Block.calibz M. Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 27, 2021 Share Posted January 27, 2021 7 hours ago, Kbird1 said: It not to difficult to do you own cross section through a single board , figure out the Tilt on it and then multi-copy it up the wall every 6" If Mick's solution is the one you are looking for (Personally I am not sure EXACTLY what that is, what he shows can also be easily done in a Back Clip Cross Section Camera (mainly used for Wall Typical's), where you then add 2D objects manually to detail out what you wish to display using closed polylines to emulate siding and trim objects in profile as it is still done in AutoCAD today and for eons. DJP Link to comment Share on other sites More sharing options...
ChiefuserMathews Posted January 27, 2021 Author Share Posted January 27, 2021 Thank you everyone for the valuable inputs. Let me try and will get back Link to comment Share on other sites More sharing options...
ChiefuserMathews Posted January 27, 2021 Author Share Posted January 27, 2021 8 hours ago, Kbird1 said: It not to difficult to do you own cross section through a single board , figure out the Tilt on it and then multi-copy it up the wall every 6" MHD_6 in Exp. Lap Siding CAD Block.calibz M. Thank you Mike. That was awesome Link to comment Share on other sites More sharing options...
